Here is the complete pinout of the main connector (on the deflection board):
SPECIAL NOTE: The 2nd printing of TM-183 has a typo in Figure 8 on page 11 which incorrectly identifies the heater as existing on pins 5 and 6. Strangely enough, both the 3rd and the 1st printings have the correct numbers; go figure.
I should also mention that the monitor Sega used in it's vector games (Electrohome's G08-CB0) is also an analog monitor and can be used in any Atari vector game (and vice-versa) with the proper adaptors to mate the different wiring harnesses (connectors) plus some circuitry to scale the voltage ranges of the analog signals and the AC supply. I do not have documentation for the G08-CB0 so I cannot say exactly what scaling is required but I can tell you that I have seen G08-CB0 monitors with "Tempest" burned into them and I also saw a Wells-Gardner with "Space Fury" burned into it. I have talked to several people who claim to have seen such a setup in action but they have no specifics. I would appreciate any details anybody can provide about the G08-CB0 and/or the specific conversion details (either direction).
David Shuman <essayes@telerama.lm.com> had this to say about the G08-CB0:
====================START====================
I know this is supposed to be about Atari monitors but here is some information the Sega color vector monitors that I found on page 12 of the November 1981 issue of the Star*Tech journal. I'll include it here just in case you have one of those hybrid setups mentioned above. If anybody knows more about the redesign that is mentioned, please let me know!
Gremlin/Sega reports that all of the problems encountered with the industry's first color X-Y game "Space Fury" have been identified and solved [yeah, right].
The problems are centered around [ack, bad puns, too!] the deflection (X-Y) amps. Under-rated power transistors combined with an extended "on" time during the power-up routine resulted in damaging the amplifier circuit.
The remedy includes a modification to the card cage and replacement of the Electrohome Monitor with a redesigned unit.
Gremlin/Sega will have replaced all defective monitors and modified all game card cages by the end of October.
Initial field fixes did not resolve the problem entirely and Gremlin/Sega decided to undertake the monitor replacement program.
Electrohome, the monitor manufacturer, will replace monitors in the Eastern U.S., while Gremlin/Sega will handle the Western U.S.
For further details contact your distributor.
====================STOP=====================
The Amplifone was commissioned as a replacement to the infamous, failure-prone Wells-Gardner. Unfortunately it had a horrendously unreliable Achilles' heel; the HV transformer. This part is widely (but falsely) believed to be impossible to replace because there are no more HV transformers around. Fortunately, this is incorrect and they are readily available, even though they are a bit expensive.
The replacement HV transformer was over-engineered to the max so that it would not fail as much as the original part and to date Atari reports that THEY HAVE NOT HAD EVEN ONE REPORT OF THE REPLACEMENT EVER FAILING! To be critical, this could be due to the fact that by the time the replacements became available, most people were no longer routing their Star Wars machines (or at least not with the Amplifone monitors in them). Any machines being repaired and used today are likely to get gentle home use which naturally lengthens the life of the monitor and its parts.
If your HV is dead then it is probably either resistor R12 near the HV transformer or the HV transformer itself. CHECK THE RESISTOR FIRST since it is much easier and cheaper to replace. Simply unsolder it and see if it has the proper resistance (2.2K Ohms). You will also want to check to see if the over-voltage protection circuit is misadjusted causing it to activate even though the HV is in a tolerable range. If LED (CR2) is lighted, then the over-voltage protection circuit is activated. If it is on then you either have a misadjusted potentiometer or a damaged HV circuit. Mark the initial position of R19 and tweak it a tiny bit to see if the LED turns off. Don't move it too much or you may damage other parts of the circuit or even your tube if the HV is indeed too high.
The catch is that Atari replacement parts are only supplied at the wholesale level to official Atari game distributors. To find out the distributor closest to you so that you can order this part from them, call Atari at 408.434.3700 and give them you Zip or Area Code and they will give you a business name and phone number. I am pretty sure the MSRP is about $160 but that is significantly cheaper than buying a Wells-Gardner retrofit that you will have to repair about once a year (most distributors discount such old parts below the MSRP so you shouldn't have to pay that much especially if you comparison shop and play the distributors off each other).
Starting with some information I provided to get him started, Tim Tewalt <tewalt@peaks.ENET.dec.com> in mid-1995 attempted to bypass Atari and the distributors by buying factory direct. Here is what he discovered:
"Flyback" Transformer for Amplifone XY monitor
   Atari part number: A201005-01
   Type number: 926862802 ("Transformer Multiplier")
   Manufactured by: WinTron Inc.
   276 Spearing Street
   Howard, PA 16841
   1-800-865-5351
   (814) 625-2720
   http://www.wintrontech.com
[NOTE: The reason for the high prices is that they do not have any stock on hand and would have to retool the machinery to manufacture a fresh batch. Perhaps it would be simpler and cheaper to get the spec from them and find out what it would cost to have a professional wire one up by hand...]
If your HV transformer is dead then you will need to order Atari part number A201005-01. This part was available in inexhaustible quantities from Atari until recently but now Atari claims they have no more. I suspect that with all the reorganizations of the company some of the "dead weight" inventory was liquidated or thrown out altogether. If you make enough phone calls to large distributors, you should be able to locate one. If you do, please let me know and I'll add the information to this document. One person reported that when his HV transformer went bad it took VR1, R20, and CR5 with it so you may want to test/replace these parts, too (they are commonly available).
Here is the document that describes how to install an Amplifone HV transformer. Thanks to Keith Jarett (keith@tcs.com) for mailing me a photocopy (who in turn wishes to thank Mark Sherman and Al Vernon of Atari Games for their fabulous in-depth knowledge and tech support. I agree; these guys have helped me a few times, too, and are fantastic).
[NOTE: To my knowledge, Atari never bothered to copyright these instructions and they are not marked with a copyright symbol.] INSTALLING THE NEW AMPLIPHONE [sic] HIGH VOLTAGE TRANSFORMER
[NOTE: End of document; here is further advice from the Atari techs...]
After you finish, you will need to adjust brightness (bottom pot on the white module). Use the self test screen for this. Also adjust focus. If nothing happens, the other (lower) focus wire is broken like mine was [NOTE: Mine was broken, too!]. Take off the rubber cap to verify. Focus is the top pot on the white module. This connection is fragile and takes a lot of heat/current so it frequently breaks off.
Adjust R7 (the frequency of the primary switching) to get a video B+ of 180 volts. According to Mark, this will give the correct HV. You don't really need to tweak R17 as described in the manual if you know that your over-voltage protection cutoff is working OK. Recheck focus after tweaking R7.
If any problems occur, verify that the +24 and -24 volt regulators are reasonably close to the correct output voltages. Some departure is OK if you have the 5 watt resistors bridging their inputs and outputs (these are present to relieve the load under transient conditions such as the all-white death star explosion).
The board should now run MUCH cooler. I can comfortably touch all the HV heat sinks which was not true before.
