// Optimized single channel quadrature to pulse converter front-end intended to be used with uMD1 // v01 - Basic implementation // v06 - Direct PORT calls // v07 - Differential output for Up/Down // Signals: A=D2, B=D3, Up_P = D4, Up_N = D6, Down_P = D5, Down_N = D7. #define FirmwareVersion 0106 #define Pin1A 4 #define Pin1B 8 #define Up_P 16 #define Down_P 32 #define Up_N 64 #define Down_N 128 #define Error 32 int oldState1 = 0; int newState1 = 0; int count = 0; void setup() { pinMode(2, INPUT); // Channel 1 A pinMode(3, INPUT); // Channel 1 B pinMode(4, OUTPUT); // Channel 1 Up_P Pulse pinMode(5, OUTPUT); // Channel 1 Down_P Pulse pinMode(6, OUTPUT); // Channel 1 Up_N Pulse pinMode(7, OUTPUT); // Channel 1 Down_N Pulse pinMode(13, OUTPUT); // Error LED PORTB = 0; // Reset Error LED. newState1 = PIND & (Pin1A | Pin1B); } void loop () { for(count=10;count>0;count--) digitalWrite(7, HIGH); // Delay to stretch LED on-time for demo. oldState1 = newState1; newState1 = PIND & (Pin1A | Pin1B); PORTD = Up_N | Down_N; // Reset Up/Down outputs. if (oldState1 == 0) { if (newState1 == 0) {} // No change. else if (newState1 == Pin1A) { PORTD = Up_P | Down_N; } else if (newState1 == Pin1B) { PORTD = Down_P | Up_N; } else PORTB = Error; // Set Error LED. } else if (oldState1 == Pin1A) { if (newState1 == Pin1A) {} // No change. else if (newState1 == 0) { PORTD = Down_P | Up_N; } else if (newState1 == (Pin1A | Pin1B)) { PORTD = Up_P | Down_N; } else PORTB = Error; // Set Error LED. } else if (oldState1 == Pin1B) { if (newState1 == Pin1B) {} // No change. else if (newState1 == 0) { PORTD = Up_P | Down_N; } else if (newState1 == (Pin1A | Pin1B)) { PORTD = Down_P | Up_N; } else PORTB = Error; // Set Error LED. } else if (oldState1 == (Pin1A | Pin1B)) { if (newState1 == (Pin1A | Pin1B)) {} // No change. else if (newState1 == Pin1B) { PORTD = Up_P | Down_N; } else if (newState1 == Pin1A) { PORTD = Down_P | Up_N; } else PORTB = Error; // Set Error LED. } }
