Instructions for Wiring the Melles Griot 05-LPM-847 HeNe Laser Power Supply
This is detailed info on assembling the Melles Griot 05-LPM-847 power supply brick with ballast resistor(s) and tube mounting brackets. The diagrams below shows the general arrangement. It is critical that the polarity be correct. The diagrams also show the polarizing beam sampler that would be required for the stabilized laser kits (or for other experiments).
Note that these power supplies have an Alden connector for the tube; A mating connector will be provided with the tube mounting brackets.
Wiring the power supply
  1. Attach the thin red wire to the positive of the wall adapter. Attach the black wires to the negative of the wall adapter. DOUBLE CHECK THE WIRING. REVERSE POLARITY WILL BLOW THE HENE LASER POWER SUPPLY OR DAMAGE IT SUCH THAT THERE IS NO OUTPUT CURRENT REGULATION - WHICH WILL DAMAGE THE TUBE. AND MAY BLOW THE WALL ADAPTER AS WELL.
  2. A screw terminal to barrel adapter is usually included to make this wiring painless. If not, or you would rather hard-wire it, cut off the barrel connector on the DC adapter cord and connect directly to the wires of the brick Refer to the diagram above for the terminals on the DC jack depending on the style that you have. DOUBLE CHECK POLARITY WITH A MULTIMETER BEFORE ATTEMPTING TO POWER THE BRICK AND TUBE!!!!
CAUTION: ALL INPUT WIRING MUST BE SECURED USING SOLDER, WIRE NUTS, OR A SUITABLE CONNECTOR. DO NOT JUST WRAP THE WIRES TOGETHER. INTERMITTENT CONNECTIONS BLOW STUFF.
Installing the tube
Examine the mirrors of the laser tube to determine the end for the main beam. In the past, most of these were from the anode-end but it can come from either end depending on the specific tube. There will be an AR coating on the output-end mirror which appears blue-ish in reflected light.
Wiring using the brackets:
  1. If the output is from the cathode-end of the tube, there should be a hole in the cathode-end bracket so the photons can escape. ;-) If not, it is possible to swap the two brackets or drill a hole. But the bracket with the red wire MUST have the anode-end of the tube.
  2. Remove the adjustable attenuator plate (if present) from the mounting bracket by unscrewing the hex-head screw. Since reducing the power of a ~1 mW laser is kind of silly, this part is probably not installed.
  3. Attach the anode and cathode mounting brackets to a secure surface spaced to permit the tube to just fit between them. For testing this step can be postponed. Depending on how the tube will be used, one or both brackets may be trimmed to free up space between them.
  4. Flip open the covers on the mounting brackets by pulling back on the locking tabs.
  5. CAREFULLY lay the tube ends on the mounting brackets paying particular attention to polarity: The positive has the fat red wire and receives the anode (glass)-end of the tube; The negative has the fat black and receives the cathode (aluminum can)-end of the tube. Make sure the anode-end bracket isn't too cockeyed to permit the beam from getting out of the hole. :) Make sure the tip-off (exhaust tube) at the cathode end clears the structure of the bracket.
    CAUTION: THE TUBE MAY APPEAR TO WORK WITH REVERSE POLARITY BUT WILL PROBABLY BE RUINED IN A FEW MINUTES. Gently press the covers in place so they click and are secure.
    Take care to avoid stressing the fat red wires to the ballast resistor. If either breaks off, it may be necessary to replace the ballast resistor.
Wiring using tube clips (if included, mostly for the various stabilized lasers where special mounting may be desirable
  1. Cut the fat wires near the mounting brackets (retaining the ballast resistor).
  2. Solder tube clips to the wires.
  3. Carefully route and secure the wires so they don't stress the conections at the tube.
  4. Gently press the clips onto the tube mirror mounts making sure they go to the correct mount: The positive has the fat red wire and receives the anode (glass) end of the tube; The negative has the fat black and receives the cathode (aluminum can) end of the tube. Make sure the anode-end bracket isn't too cockeyed to permit the beam to get out the hole. :) Make sure the tip-off (exhaust tube) at the cathode-end clears the structure of the bracket. CAUTION: THE TUBE MAY APPEAR TO WORK WITH REVERSE POLARITY BUT WILL PROBABLY BE RUINED IN A FEW MINUTES.
WARNING: THE VOLTAGE BETWEEN THE ANODE AND CATHODE OF THE LASER TUBE MAY BE GREATER THAN 5,000 V WHILE STARTING AND GREATER THAN 1,000 V WHEN RUNNING. TOUCHING THIS WILL PROBABLY NOT BE LETHAL BUT YOU WILL FEEL IT AND PERHAPS TOSS THE ENTIRE RIG ACROSS THE ROOM. :( SIGNIFICANT CHARGE WILL REMAIN ACROSS THE TUBE AND POWER SUPPLY FOR SOME TIME AFTER INPUT POWER IS REMOVED. USE A CLIP LEAD ACROSS THE TUBE TO DISCHARGE BEFORE TOUCHING ANYTHING TO BE SAFE.
